V6 airbox
+1.
Unless you're lucky enough to find one secondhand or lying about on the floor in a parts department then R-Sport are your best bet. R-Sport can also get you the Inlet Hose and the Airbox Bracket, but be warned the whole lot comes in at ~£200 before you sort out the panel filter and have the battery relocated. It's well woth doing, but it's not a cheap modification...
+1.
is that £200 including the bracket and hose pal??
For a new Airbox, Bracket and Inlet Hose you're looking ~£200.
Filter, Dry-Cell and battery relocation is ~£200 on top. :001_rolleyes:
That's the old shape one, the one you want for the 197/200 is triangular;
ahhh i see so all in rough figure of £400 then cheers pal:smile:
any numbers i can use to ring through and get one by any chance? and im guessing we'd also need to state which type of box we need??
