Raptor6767
Gold Member
the holes are already in those positions, so its just a case of a nut and bolt.
Does the 'nut and bolt' fit in from inside the car or from the outside and needs the splash guard/inner wheel arch removing?
Better turn in etc, that will have far more to do with your extra camber!
Did mark fish set your car up?
Sounds like a good setup tho!
How much was it for him to set the car up? If you don't mind me asking
ok a bit of an update from me regarding the UR products.
I've read somewhere in the forum that ''people put rear anti roll bars and often end up in the ditch''. Well, this is definitely NOT the case. Unless of course they feel more confident with car and they try to carry twice as much speed in the corners or something.
I fitted the front strut brace and the RARB on Wednesday. You can immediately tell when you've fitted the front strut brace as Raptor said but regarding the RARB that wasn't the case. it was pissing down and I couldn't drive the car as aggressively as I wanted so yesterday i gave it a blast and yes, oh yes, the car feels more balanced and the turn in is simply superb. I mean clio has endless amounts of grip anyway but trust me a very good car becomes better. You can actually feel the weight staying at the back during cornering making the job of the front outer a bit easier, hence more grip. This part SHOULD have come with the car, stock!
I also had a thorough talk with mark fish about anti roll bars in general, the guy does know his stuff and I've ditched the idea of putting a thicker ARB in the front. Now bear in mind that I fitted the bars alongside lowering springs and adjustable top mounts and running 2.1 degrees negative at the front. Maybe the whole package is responsible for transforming the car but trust me, that bit of understeer I used to have in hard cornering is now gone. My opinion? Get the RARB. It's a cheap and extra effective mod!If you are not happy you are more than welcome to shoot me
I've read somewhere in the forum that ''people put rear anti roll bars and often end up in the ditch''. Well, this is definitely NOT the case. Unless of course they feel more confident with the car and they try to carry twice as much speed in the corners or something.
Uh...if I could have 2.1 camber...
This probably the mod that gave you most of the grip.
yes 519 automotive sell them i went up there the other week to get matched inlets fitted and he showed me them and he seemed to have quite alot of the range in stock for the 197/200
IMO it would do the same job if you cut the top bit off !
[MENTION=51010]madlynx[/MENTION] The strut bar will not fit you car as you have the smaller top mounts. All the other braces like the rear arb, rear boot brace and the front under chassis brace will still fit.Hello,
I'm planning on buying an Ultra Racing 2 point front strut bar (UR-TW2-990) for my Renault Clio RS 200 (mk3 2012). I was told that this bar might not fit cars produced after 07/2011. Since my car is 2012 I'm a bit worried that brace won't fit.
I've attached a picture to my post. Would you be able to measure actual distance between 2 bolt holes (marked by green arrow on the picture)? I'll check if it's the same as on my car.
Thanks in advance for your help!
@madlynx The strut bar will not fit you car as you have the smaller top mounts. All the other braces like the rear arb, rear boot brace and the front under chassis brace will still fit.
BAF Motorsport K-brace vs Ultra Racing | Interior and Audio | 6 | ||
Ultra racing lower brace | Car Parts For Sale | 1 | ||
S | Full set of ultra racing strut braces | Car Parts For Sale | 11 | |
Ultra racing rear brace | Car Parts For Sale | 1 | ||
Ultra racing rear brace | Car Parts For Sale | 0 |
