Two pumps to get a solid pedal!!
Having a issue with the brakes on the car. I am getting a really spongy pedal where it would go 3/4 of the way down but if i pump the break i get movement of about 1/8th. I never know when its going to do it. But i have to pump the brakes to stop now to ensure it will stop in time.
Just had h&r springs fitted but nothing happend till 5 days after.
Changed the fluid today and still the same!!
If you have to pump the pedal to get pressure it means there's air in the system, flush it through with new fluid again and you should have a firm pedal again. I don't think you can have fully flushed it through!
Found my issue tonight. Springs were fitted and shaft damaged along with hub nut. This is causing the disc to move very badly !! Cowboys
