Any reason you'd go gripper diff over say a Quaife? I'm thinking LSD next year, looking at opinions!I need to check prices as I'm planning on the following too:
Gripper plate diff
Steel lightened flywheel
Also need to see what my options are around gear ratios as I'd be tempted to keep the 197 ratios over the Meg ones with a LSD fitted to the 197 box.
Thanks for taking the time to reply. Appreciate it. Food for thought...!Superiority more than anything. The Gripper diff is a plate type and the Quaife is a ATB (Automatic torque biasing). They function differently but they both improve grip and handling by way of limiting the amount of wheel slip.
The Quaife ATB is fit-and-forget and low maintenance. It's very effective when the car has good grip on both wheels but it biases torque to one wheel over another, and doesn't completely re-direct it to one wheel in the event of complete loss of grip on one side. It never fully locks.
The Gripper diff is more complicated and its action is different. Plate diffs are usually configurable with ramp angles and pre-load which makes it more tuneable to the driver preference. Plate diffs can fully lock, if they are configured appropriately. It's action is generally faster than an ATB, but more aggressive. They do need annual servicing dependant on use and require specific oils too.
ATB diffs are popular for road users or track days and are smoother and consistent. Plate diffs are more aggressive but are for motorsport or hard use. The fully locking function also means if you break a driveshaft the car will still limp off a circuit or stage where are the ATB or standard 'Open Type' wont.
Quaife seem to have a good offer on at the moment. Hope that helps mate.
Can run 20mm spacers with standard speedlines, in running 225 and had space front bumper a tad. If running 215s you'll be fine.
I think this may have inspired my next wheel colour [emoji6]
Message Paul Temperton on FB mate. He'll be able to sort you out a price.How much was the splitter if you don't mind me asking?
Laguna wheels look sexy as hell. Will look lovely on-car ! As does the splitter.
Great paintjob on the wheels too. Rattle can yourself or....?
Presume the Laguna wheels are for the Track as they have slicks on ! I've seen a few with these. Is the offset suitable with no extra spacers etc ?
Thanks mate. Yes just a rattle tin, should give it a Williams look. They are just for the track days. They are a straight fit and only £15 each soman absolute bargain. I'll be running 20mm spacers as I want the wheels to fill the arches.
Hoping to sort out a F4RT motor shortly too .
Clio 200 - Replacement Rear Calipers? | Suspension, Brakes & Steering | 1 |
