doing cadwell in the Clio 200 in a few months.
I'm not new to these days and done plenty in my 182 and my setup on that was atf200 brake fluid, carbotek xp10 pads and Brembo hc discs, I overcome heat by removing fogs and arch liners, I could go all day on that setup and I drive hard.
Now moving onto the 200 it's my first day in the car and the setup of choice is atf200 fluid, ds1.11 and whatever the drilled and grooved discs are already fitted.
Rears are std and will stay that way.
Does the 200 suffer from excessive heat like the 182? Should I pull the liners and fogs for airflow?
I'm kinda looking to see what you run on track and any issues you've had tbh.
I hate the initial testing and failing stages of a new car and I'd like to elimate as much as possible before arriving on site.
Many thanks
Many thanks
