Touchscreen radio/sat nav upgrade??
Hi,
I’m looking at upgrading my factory stereo setup to some kind of touch screen setup. Has anyone done this? Need advice/option ideas? These photos are what I’ve already seen online and I’m thinking of doing the one that’s on top of the dash where the time/temp screen sits.
Quite a few possibilities when it comes to ICE. As you've seen, the centre console can be modified to fit a double din unit, you could also install a single din unit which has a screen that slides out.
If you want something different, you could also install a tablet in the OEM satnav housing. I had a tray 3D printed which would hold a LG G3. You could even install a car PC using a raspberry pi and a touch screen if you really wanted to.
I think the easiest/most straightforward option would be a single din with a slide out screen like this.
