The sticky handbrake problem....
Mike
Gestapo
Has now been solved :wink:
There are two springs on the back caliper that were both gone on mine. Been replaced it its working fine now :smile:
New brake fluid, and even the fronts are now working 500000000000000000 times better than before. I'm glad :smile:
i cant see that being the issue to be honest unless the spring push the pad away from the discs which i dont think they will.
i could be wrong
i could be wrong
Well, before it went in, the handbrake wouldn't totally disengage.
After the two springs have been replaced, it disengages.
Me thinks it was the problem :wink:
ohh i see . . . . i thought you ment the problem with it sticking when wet
sorry
