I'm sorry mate I've got no idea what you're talking about in that second bit ha ha.
Ah thanks buddy that makes sense to me now ha ha.R3 is the Clio rally car. You can get an R3 access which is your basic 230bhp model or the R3 Maxi which is the daddy with 250bhp.
Are the runners on the standard one tapered though perhaps, hence 'small' ports? Tapered setups usually work well because gas speed is kept high.
R3's even at 250 spec run a standard inlet, now I know reg's mandate this and ITB's would be 'better', but, it would be good to find out if any work is done to the stock inlet or not in either 230 or 250 R3 trim?? Because clearly it's got enough potential in it to be suitable for std cams and wilder ones.
Well, to correct Fenandez, there are 3 levels of R3.
1) R3 Access is the basic one, but it is not 230bhp, it is a standard 197bhp engine (of course blue printed). Exhaust is different but exhaust manifold is stock (albiet empited pre-cat iirc), inlet is same as Cup Racer.
2) Then there is the R3 Maxi which is 230bhp. Big spec changes, manifold, cams, exhaust, uses Cup Racer airbox too.
3) From 2009 the R3 Maxi 'Evo' spec which is 250bhp. Even more changes including the fancy airbox arrangement.
I can see that all 3 use the same part number for the inlet manifold and TB, we would need to speak to the likes or Oreca as to if they do any porting on Maxi or Maxi Evo spec's, however I would suspect not because otherwise it would likley require a new item/casting to meet any FIA sanctions/approval.
Without wishing to put this after market 'bored' manifold down, I would want to see some solid back to back testing done on it and watch what it does to the area under the curve not just peek fig's etc.
M | Sussex 133 owner | New Members | 3 | |
200: Looking for a specialist: East Sussex or London | Clio General Chat | 7 | ||
New member for Sussex | New Members | 14 | ||
S | Soon to be 197 owner Sussex | New Members | 10 | |
D | Where to get Remap near Guildford or in Sussex? | London & South East | 6 |
