I've got an issue with my front wipers, I couldn't find the exact answer from other posts.
When I put the wipers on nothing happens, sometimes if I put them on max speed they will wipe but slowly.
I've had the usual issues with seized linkage before so today I removed the linkage to check and it was moving freeley.
Reassembled and with out the wiper arms fitted it seems to run fine, as soon as the arms are fitted and there is a bit of resistance it either won't wipe or stops mid wipe.
Any ideas on what else to check? Is it possible the motor is just knackered?
Cheers Matt
Cheers Matt
