Strange squeak from the front left at low speed
My 197 has started to squeak at low speeds, sounds like wheel bearing perhaps but im just wondering if there are any common problems, its from the front left at low speeds on and off corners don't seem to effect it but a dab of the throttle or brakes normally makes it dissappear for a few seconds
BREMBO calipers need a clean.
Depending on mileage, replace the piston seals too (on the brakes).
Squeek squeek squeek squeek.
Calliper probably seized, the backing plate on the pads corrode and seize them self to the calliper. Get the pads out, and give them a good clean then re assemble using copper slip on the sides of the pad backing plate.
The pins can be an arse to remove, Mr pink on here sells some up dated pins that use R clips
as said brakes - give them a good punishment and see if it alters it...bearings don't "squeak" as such but brakes do
