littleg78
Alternator died on way to Thruxton last Sunday, and had it replaced by a local RAC approved garage.
Since then I consistently get the STOP low battery warning 13/14 minutes after starting the engine - doesn’t matter if it’s a cold start or engine off/on again, and doesn’t matter what accessories are turned on/off or if car is sat idling or being driven hard.
Battery is in good condition with 12.8v when engine off.
Alternator providing consistent 13.9v across the battery with engine on.
All accessories working correctly and car driving as it should!
I saw a thread that mentioned disconnecting the battery for an hour might fix, but when I reconnected fault was still present. Might try disconnecting battery for a couple of days - not sure if Clio has some kind of backup battery that needs to discharge for full “reset”.
Failing the above not really sure what to try next. As it’s a Meglio I’m not sure if using the original Clio 200 alternator, or one that came with the 225 engine. All the garage said is that the original had a single pin terminal, and the replacement had two pins. The replacement was a Bosch 110A for Megane 225.
I don’t have Clip but thought that might shed some light once the faults active on the car?
Other than this niggling problem she’s in super shape so keen to get fixed for peace of mind before Cadwell next month!!!
