Steering assist adjuster
l33th3tr33
Hey guys, has anyone fitted an adjuster for the electric steering assist? I know some of the ph2 boys have done it in the past with different racks and I noticed you can actually buy an adjuster but will need it coding or something?
Basically I'm after some advice on if it's worth it, cost Vs ballache to fit.
Ph2 cars had power steering pumps the mk3 has electric power steering which can be reprogramed for the amount of help it gives and at what speed (lighten the steering). Or are you looking into a faster rack which means less turns from full left to full right.
I was going to try adjusting this, if you look at the ECU in ddt4all it has a setting from 1-14 with the RS set to 14 as the default.
Perhaps not relevant but... I have the RSTuner from Fastchip.nl and paid for the EPS module (I have a 197) and it unlocks the ability to read faults + change the steering strategy...
Decent bit of kit (the RSTuner as a whole). Perhaps this helps?
Reactions: EthanMenace
