Starting with ignition by it's self
Mdg197
Hi. Iv got a 197 full fat but car has started starting as soon as the ignition button is just pressed with clutch and brake not pressed at all.
Is there a common fault for this like faulty clutch switch or brake pedal good switch?
No errors logged in car memory
Could be either the brake or clutch switch.
Check to see if your brake lights work. That’ll tell which it is.
Either the switch needs adjusting, or is faulty.
