Phenom
I've got a almost constant very loud squeak coming from my rear drivers side. I'm pretty sure its something to do with the brakes as the rare chance i get in the car and its not squeaking but it is guaranteed to start at some point in my drive if I hit a slight bump or stamp the stop pedal a bit too hard.
about 1000 miles ago replaced discs with the Godspeed G hook discs, new genuine pads and my driver side rear caliper with a refurb as it was seized.
the problem was slightly intermittent before that but it has got worse and worse as time has gone on.
the squeaking noise gets worse when I'm turning left
there is no noise when turning right or reversing.
squeak will be slightly quieter if the car has been parked facing uphill or with the drivers side parked up a curb.
at first i thought i had warped a disc but because it doesnt make the noise all the time I think that not the case? unless I'm wrong here?
what else can be the cause of the noise?
Thanks in advance
**will add video of noise after work if needed
Thanks in advance
