Something's bent
Dave W
So yesterday I had a bit of an off at Loton Park, slid across the grass, over the top of a bank and landed with a bump. The NSR now runs a lot more camber than the OSR and I suspect as it landed it dragged the bottom of the wheel outwards.
Strangely, it actually steers and brakes in a straight line (well enough to do a second run with no issues) but before I stick it into Rentune, are there any sacrificial components that will bend before anything serious goes west?
I'd be guessing it's the beam . Not much else to bend at the rear
Sent from my SM-G981B using Tapatalk
Yeah prob sounds like a beam..
Could have bent the dampener.
you got a full rear interior?
Yes, we’re obliged to run full trim. I might pull it out the rear to see if there’s anything but it does just look like the camber is out, it’s not sitting low or anything that I can obviously see.
If it's camber it'll be the beam unfortunately, might get lucky and stub axle change might sort it, but normally it's the beam.
