Hi,
My front wipers have suddenly gone slow. Few weeks back I cleaned out the drain holes behind the wipers, they werent too bad and i sprayed some greese onto the moving parts. Then last week i fixed my indicator stalk as flashing the lights was temperamental and when putting the plastic steering column casing back on the screw went through one of the red wires coming out the indicator stalk. So i soldered it back to together and everything on both stalks works fine.
So what could be the problem? Has the greese caused the problem? Did i tighten the wiper arms up too tight? or is the soldered wire the problem?
Any help you guys can give would be very helpful
