sorry should have checked
http://www.clio197.net/forum/payments.php and subscription starts from £5 but its well worth it.
here is a list of just a few of the guides on how to do things to your car.
Service
197 Service Schedule (assume 200 is same): Clicky
Engine Bay
Guide: How to change ALL the front bulbs on a 197 & 200 (including projectors): Clicky
Guide: Access standard headlight bulb passenger side: Clicky
Guide: Where is the engine bay fuse box located: Clicky
Guide: Get side light bulb holders out to fit led's: Clicky
Guide: 200 bulb change made easy: Clicky
Guide: Working the throttle body: Clicky
Guide: Clio 200 Bi Xenon retrofit: Clicky
Guide: Panel filter replacement: Clicky
Guide: Change gear box oil: Clicky
Guide: Change spark plugs: Clicky
Guide: Oil Change: Clicky
Interior
Guide: Remove Door Card / Speaker / Stop Door Handle Creaking: Clicky
Guide: How to remove seat backs for dipping/painting: Clicky
Guide: How to fit Sprintbooster Gen 2: Clicky
Guide: How To Install Renaults TunePoint: Clicky
Guide: DIY Aux for Cabasse Changer: Clicky
Guide: Replacing Cabin/Pollen filter: Clicky
Guide: Steering Wheel Removal: Clicky
Guide: Changing glove box light: Clicky
Guide: Removing Glove Box: Clicky
Guide: Rear Seat Removal: Clicky
Guide: Dash pod removal: Clicky
Guide: Changing Seats: Clicky
Bodywork
Guide: How to adjust the boot striker without removing any trim: Clicky
Guide: Where to cut the standard exhaust to remove it: Clicky
Guide: Fit a trs tow loop to a 200: Clicky
Guide: Front Diamond Removal: Clicky
Guide: Exterior handle removal: Clicky
Guide: Replace weather strips: Clicky
Guide: Removing 197 Diffuser: Clicky
Guide: Front bumper removal: Clicky
Guide: Removing Mirror Caps: Clicky
Guide: Door Bullet Removal: Clicky
Guide: Rear Tailpipe Trims: Clicky
Brakes
Guide: Strip and clean the front calipers and change pads: Clicky
Guide: Strip and clean the rear calipers: Clicky
Guide: Quick check of your brake pads: Clicky
Guide: Front pad replacement 197: Clicky
Guide: Brake Fluid Change: Clicky
Guide: Change front discs: Clicky
Guide: Change rear discs: Clicky
Guide: Painting calipers: Clicky
Electrical
Guide: Reset service light: Clicky
Mechanical
Guide: Seized Wiper / Wipers Stopped Working Cure: Clicky
Guide: Rear Lower springs/Dampers: Clicky
Forum
Guide: Applying an Avatar: Clicky
Guide: Posting pics: Clicky
Other
Guide: Jack up a 197 and place on axle stands: Clicky
