When I changed my belt at work I had the choice of 2 horse shoe timing tools, they both had the same timing tool number but the profile of the tips that sit in the cams were slightly different. So 1 was a very snug fit as where the other wasn't but IMO would still do the job as I used both tools and was fine.
Bebbetufs you maybe have struggled like I did to refit the timing tool after manually turning the engine over as turning it over takes up the tension in the belt and the slightest of slake between the 2 cam gears will cause the timing slots to be slightly out of line. It took me a second go to align it correct but the auto dater book I was using explained to free the cam sprockets from the cams after fitting the timing tool, fit and tension the belt then tighten the cam sprockets remove timing tool and turn over this should eliminate slack between the cams therefore the timing tool should slide in after turn the engine over. Surpose u haven't got to worry now though as it done![Smile :smile: :smile:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
