WheelerDave
I just wanted to share this in case it’s of use to someone else in the future.
We had to replace the horn on my son’s RS200. Once we found it it was relatively straightforward.
It is located behind the bumper, in the middle at the top, in front of the radiators. To get to it you can take the front bumper off, or we just removed the 2 screws on the top of the bumper where it sits on the slam panel, together with the 2 plastic push clips on the same panel. You can then just pull the top part of the bumper forwards to see the horns.
Best next step is to undo the 13mm nut holding them on. It’s located in the middle of the 2 horns, then remove together with the bracket and unplug.
We then found the exact match for the horns on eBay. Just search:
927695 Pair Horns Horn Fiamm AM80S KIT 2TJU 12v Car Vehicles Com Relay
They come with the correct wiring etc, so it’s a plug and play. Also only cost £28.95 delivered.
Reassembling is the just the reverse of the above once the new horns are mounted on the bracket.
Hope this helps somebody else one day
