Hi all,
I noticed my reverse lights were out so tried the easy option of replacing the bulbs but no luck. I tried my rear fogs as well to test all the other lights and these were out as well so I can only assume a fuse has gone. However does anyone have any ideas which one it will be because looking in the manual I can't see which of the fuses under the steering wheel it might be!? Or any other ideas what the problem may be? If not I will just have to go through all the fuses by process of elimination. Cheers,
Josh
Josh
