I'd like to fit a light weight pulley.
From searching it sounds it can be accessed from the wheel arch and removed with a air gun.
Timing shouldn't be affected as the belt is sitting on a sprocket on the other side of the crank pulley.
Is it easy enough to do up to the correct torque again? Can the engine just be left in gear or does the flywheel need locked?
