Recaro Tilt Release Cable
Sunglasses_Ron
Administrator
Has anyone ever replaced the tilt release cable on a set of Recaros?
The drivers side on mine will release the seat to tilt forward but doesn’t release the seat to go forward on the runners.
How do I go about replacing the cable?
Is it an easy job or should I get it done professionally?
Are you gents sure its the cable thats broken? Theres a part that unhinges near the runners to allow the seat to move forward. If you look underneath there is a bar that is attached to two spring loaded mechanisms. Sometimes bits fall off or come out of place.
Reactions: Mossy
I’ve got the same problem on the drivers said and so does @RossWoods93
Who I believe has sorted / got parts to sort it ? He maybe able to help
Apologies, only just seen this!
I have exactly the same problem, of which the part is about £40 from memory. I've not fixed mine as yet, as it's not often I have rear passengers.
I've been told it's not too difficult of a job, you remove the base of the seat held in by 4 screws, and should be able to re-thread the cable. It may be a case of taking the base off and visually inspecting if it is a simple job, but I'm yet to tackle it as yet!
