Rear airbags
Hi everyone,
So I have removed the rear seats, belts and curtain airbags.
I've put 3.9 ohms resistors soldered to the wires for the above. However, I still have the airbag light on the dash.
Checked the resistance with car was running and I get between 2.6 and 2.9.
Am I missing something? Does the light need to be re-sent?
Never worked on Renault's before as had Fords s track cars piror to this.
I don't think all the airbags are the same resistance and you don't know for sure without a code which airbag is causing the light as the under front seat and dash airbag connectors can sometimes cause the light to come on as the resistance goes outside the limits. And I don't know about the other items like the drivers seat position switch that signals if the seat is locked in position or tipped forward.
Reactions: J18NYR
Thank you for this, gives me more areas to test.
