Pure motorsport gear linkage Setup.
Hi
Does anyone know any video out there for setting up one of these shifter, I had to install a new engine mount on the gearbox side and now have a problem getting into 1st and 2nd gear and it not the gearbox or clutch.
Sounds like you need to adjust rod 2 or maybe just adjust the position of your engine mount and tighten back up
If you’ve would out rod 2 too far you can lengthen the M10 rod and that has the same effect, you can then wind in rod 2 so it’s not extended too far
Yeah thanks for your help, I managed to clean the rod ends, and then applyed some oil, and adjusted the engine mount down by a couple of mm, seem to have done the job.
