Projectors for a 200
lild-200cup
Looking at ordering some projectors next week just wondered if they are direct replacement from the standard ones I no the cornering lights don't work but does the headlight height adjuster work inside the car and are the side lights the same bulbs (501)
Cheers dan
I put some on my Cup. Direct replacement. Just take the motor unit off the back of the cup headlights (takes 10 seconds) and put 'em on the projectors.
All bulbs are H7s but for the main projector bulb which is H1 (IIRC).
Not quite a direct replacement! Dont forget the headlights you remove will have a plastic trim riveted to the base that helps the bumper sit flush, so remove this from your headlights and cable tie it to the base of the cornering headlights.
ok cheers guys. is the bumper easy enough to take off as i guessing this will need to be removed in order to fit the new lights?
