I have the same as mattb_197 and they are absolutely bang ok. Fitted myself using the guides on the how to section
thanks Matt..could you link me to those you have on pls??I've got the Powerflex lower dog bone insert and the upper torque bush mount on mine. Spot on, not too many vibrations once they settle in and a positive difference in the way the car drives, no more rocking from the engine when you go on/off throttle. I'm not sure I'd want to add any more as I use the car as a daily so wouldn't want to introduce too many cabin vibrations.
Yup same set up for me and it's brilliant - didn't fit myself though :001_unsure:
Still waiting to hear some solid feedback on the gearbox mount before deciding if it's worth fitting that too. Hopefully Pav will be the guinea pig![]()
hey, I'm from south Africa, ordered all the engine mounts and the gearbox mount, will have them delivered and fitted in the next 3 weeks. will give feedback when it's up and running.
hopefully it will not rattle the crap out of me but was forced to go this route due to oem costing twice the price for two mounts compared to getting all Powerflex mounts. we get priced raped in South Africa
thanks buddy :thumbup:The ones I have are parts 20 and 23 on the diagram below:
-Lower engine mount insert - PFF60-820
-Upper engine mount torque bush - PFF60-822
http://www.powerflex.co.uk/road-series/products/Clio+III+Sport+197-200+(2005+-+2012)-2881/1.html
If you google/ebay the part numbers you should be able to find them. I think they were around £25-£30 each iirc so not ridiculous and make a very positive difference.
