200: Possible Over-Rev damage?
Was taking my Clio rs round the nurburgring last weekend and I believe I might've accidentally shifted from 3rd to 2nd (I'll try to attach a video) as i couldn't get it into 4th. Was just wondering what damage I should look out for and what I should do. Im not sure I even went fully into 2nd as I don't remember feeling much of a jolt. The car has also done another lap and driven 8 hours / 400 miles back home with no issues. I'm just paranoid
You could use a borescope down the spark plug holes to check for damage (piston to valve contact), and/or take the sump off to check for rod damage. But if it's running OK then I'd just forget it personally.
Reactions: Luc
Yeah I have been trying to forget cause it seems fine haha but it's hard. I'm tempted to take it somewhere to get an engine health check anyway
Compression test, if you have bent a valve it will be obvious however if it has survived since I wouldn’t be concerned as it would have likely already dropped by now..
Reactions: RSRowe and Luc
Thanks this eased my nerves a bit haha. Might get compression done anyway to be safe
