PMS Shifter Kit - thoughts?
bedoef
Hi guys,
Time has come to replace my stock shifter linkage and cables, and I was thinking to get the PMS kit to do away with any issues with slack, etc. Car is mostly a track car with some intermittent daily / weekend driving duties, and has almost full interior, carpets, etc.
I know a few guys on here have the kit already, but I haven't seen any long-term reviews. Can anyone share their thoughts on owning it for longer term? How is the setup / adjustment / maintenance on them? How are they to live with?
DafyddJones
I’ve had this shifter for over a year now and I’m really happy with how it feels, used the car with daily for a while but now it’s my weekend/track car now. It does produce a slight vibrating/rattling noise at times but for what I use the car it doesn’t bother me. The feel of the shift makes up for it. It does ideally require maintaining which is one con over a cabled shifter, which I haven’t done yet and I think my rods are starting to rust. I’ll be stripping them down and greasing them up soon.
burrellbloke
Sorry to hijack the thread but has anyone here used both a PMS shifter and a ZPO who can give a comparison/review?
PITA
Setup took a bit of back and forth to set the gate so that you had to lift the collar for reverse. After that it’s been perfect, I’ve not needed to re-adjust it or maintain it.
I love the position and feel compared to the standard shifter but I’ve not had a ZPO to compare.
Reactions: bedoef
Onrus
My buddy had a CAE shifter for a while and was never happy with it. He then fitted a PMS shifter and has gone back to the stock setup which he thinks is better than both those aftermarket options.
R20BTG
There is another cheaper option which is to retain the stock shifter mechanism but install a Wheeler Motorsport raising kit:
It is effectively a tower that raises the whole setup but needs new holes drilling in the bulkhead to pass the cables through.
Josh really knows his stuff and makes some nice kit. Well thought out and researched with high quality manufacturing.
Reactions: Don Hogg
bedoef
Any chance you can get some feedback from him and share? I would be curios to know why he didnt like either.
bedoef
Yea I saw this earlier, but I want to be able to revert to stock without much hassle, including filling in holes etc. Definitely looks like a good bit of kit!
I have had both the CAE and the PMS. I found that with the CAE (it might have been an installation issue) but I occasionally got a really jerky gear change from 1st to 2nd. It wasn't consistent at all ( sometimes when warm, sometimes during cold operation). I could never pin point the issue ( my mechanic looked at it several times). The other thing I hated was the additional noise from the gearbox and diff. Don't get me wrong my car is not quiet ( Full exhaust systems and Jenvey's) but that is nice noise, not the awful scrapping kind of noise you get from the gearbox. If your car was fully stripped you probably wouldn't notice but my car is still primarily a fast road car with occasional track use (8-10 track days a year).
The PMS was different again, very smooth gear change, not as much force required as with the CAE but it felt a bit sloppy going into gear. The OEM unit has springs to help with that 'return to neutral' feel when you take it out of gear. After repeated attempts to find the right shifter I am back with stock and couldn't be happier.
Hope that helps...
Reactions: Onrus and bedoef
bedoef
Hope that helps...
So the PMS unit doesnt have the neutral locator springs? does that mean I have to purposefully put it into the center, etc?
