Parrot MKi9200 install
Hi Guys,
I will be installing a Parrot MKi9200 later on. I don't believe my car has cabasse so I will try and write up a little guide later on as I have not seen a guide for a Clio without cabasse! It looks easy enough!
It is v. easy, only tricky bit is wiring the aux into some RCA's, or in a 200 possibly into the wiring going to the aux in socket.
You may need to switch around the perm and ign switched power.
Can you separate the aux from the parrot and leave the original aux in? if not I will just unplug the original or possibly try and look into using that with the parrot
Also with the power do you mean switching A + B in this diagram?
Pleased to have been a help!
Did you have to switch A + B?
Did you use the aux in, or do you just have it set to mute on streaming?
