OE Part Numbers & Info (Brake Discs)
Ex-User (53328)
CLIO Mk3 - 197/200
FRONT - Renault OE Grooved Brake Discs RenaultSport Clio 197/200
OE Pt No. 7701210178
These 312mm front brake discs fit the MKIII RenaultSport Clio 197/200 all variants including Cup, Cup Packed, R27, Gordini and Raider models
REAR - Renault OE Grooved Brake Discs CW Bearings and ABS rings RenaultSport Clio 197/200
OE Pt No. 8200883862
These genuine rear brake discs fit all the MKIII RenaultSport Clios 197 and 200 cars including Cup, Cup Packed, R27, Gordini and Raider models
FRONT - Renault OE Drilled Brake Discs -Front- RenaultSport Clio 197/200
OE Pt No. 7701208843
These front drilled brake discs fit all the MK3 RenaultSport Clio 197 and 200 cars including Cup, Cup Packed, R27, Gordini and Raider models
REAR - Renault OE Drilled Brake Discs CW Bearings and ABS rings RenaultSport Clio 197/200
OE Pt No. 8200650483
These genuine rear brake discs fit all the MK3 RenaultSport Clios 197 and 200 cars including Cup, Cup Packed, R27, and Gordini models
MEGANE MK2 - 225 /230 /R26R
FONT -Renault OE Drilled Brake Discs RenaultSport Megane 225/230
OE Pt No .7701208843
These front Renault drilled brake discs fit all MK2 RS Meganes including 225, Cup, F1, 230 R26 and R26R models
REAR - Renault OE Drilled Brake Discs CW Bearings and ABS rings RenaultSport Megane 230
OE Pt No. 8200650483 - (30MM BEARING)
These rear discs are for the phase 2 230 R26 models with the 30mm bearings.
REAR - Renault OE Drilled Brake Discs CW Bearings and ABS rings RenaultSport Megane 225
OE Pt No .8200443579 - (25MM BEARING)
These rear discs are for the phase 1 225 RS Meganes which have the 25mm bearings bore size
FRONT - Renault OE Grooved Brake Discs RenaultSport Megane 225/230 R26R
These front Renault grooved discs are factory fit on the RenaultSport Megane R26R, but will fit all MK2 RS Meganes including 225, Cup, F1, 230 R26 and models
REAR - Renault OE Grooved Brake Discs CW Bearings and ABS rings RenaultSport Megane 230 R26R
OE Pt No. 8200883862 - (30MM BEARING)
These are for the MK2 phase 2 RS Megane 230 R26 , R26R and DCi 175 models with the 30mm diameter bearings
MEGANE MK3 – 250 / 265
FRONT - Renault OEM Grooved Brake Discs RenaultSport Megane 250/265
OE Pt No. 402060019R
These front Renault grooved discs are factory fit on the RenaultSport Megane Cup models but will fit all MKIII RS Meganes including 250, 265, and Cup models
REAR - Renault OEM Grooved Brake Discs RenaultSport Megane 250/265
OE Pt No. 432020026R
These rear Renault grooved brake discs are factory fit on the RenaultSport Megane Cup models, but will fit all MKIII RS Meganes including 250, 265, 275, Cup, and Trophy models
FRONT - Renault OEM brake discs RenaultSport Megane 250/265
OE Pt No. 402060012R
These front Renault discs will fit all MKIII RenaultSport Meganes including 250, 265, Cup, and Trophy models - Except the 2014 RS 275 Trophy-R which had the larger 350mm front brake discs
REAR - Renault OEM brake discs RenaultSport Megane 250/265
OE Pt No. 402023273R
These rear Renault discs will fit all MKIII RenaultSport Meganes including 250, 265, 275 , Cup, and Trophy models
Reactions: Jim_ and Jimmy
Probably going to make a fool of myself here but first doing brake maintenance as never had anywhere to do it so now I have a garage I want to replace all discs and pads after having the car 2 years. Am I right in thinking that all parts with the OE Pt No. will fit my 197? I ask because when I enter car details on websites it only shows me one or two options i.e no drilled discs. Also keen to know what discs and pads you more experienced people would suggest. My limited knowledge says drilled discs are better in wet conditions.
