O2 sensor replacement
Discussion in 'Clio 197 Area' started by Meas14, Oct 7, 2019.
  1. Meas14
    Meas14 Gold Member
    4
    Car:
    Clio 197
    Searched around the forum and can't find any guides on replacing the first O2 sensor.
    Anyone have any tips or pics?
  2. Antti O
    Antti O Gold Member
    1,526
    Mikkeli, Finland
    Car:
    Clio 197 Ultra red 2007
    Mine was replaced when exhaust manifold was off from car. I bought genuine one from Germany it was something like 60euros.
  3. turkie172
    turkie172 Paid Member
    1,027
    N. Ireland
    Car:
    197
    The genuine ones are Bosch there are two types of connector one rectangle the other oval, the part number stamped on the side of the body is not exactly correct as the same sensor can have different lengths and connector type so different part numbers with the same body. There was a section somewhere on the Lambda sensors but I personally find it hard to find things in the forum without lots of similar posts coming up.
  4. Meas14
    Meas14 Gold Member
    4
    Car:
    Clio 197
    Thanks all.
    Recently had the manifold replaced (on the side so can't really take it back and complain).
    Is the only way to replace it to take the Mani back out?
  • Share This Page
