Hi Chris thanks for the advice.
I have a 200 cup and I have noticed my gear changes have become slightly notchy over the past few months. It feels the same in every gear. As I go to change gear I expect a nice free flowing smooth gear change, although feels like I'm having to put effort in to get it out of gear and then into gear, I don't have any crunches just notchyness. It is also hard to select gear on cold mornings, What do you recon as I am worried the clutch maybe dragging. I have already had my brake fluid changed and bleed recently by a trusted mechanic, don't think they bleed the slave cylinder though.
I'm going to Ktec for a 36k service next Tuesday and will get a technician to drive it and see if they can diagnose what the problem is, after seeing this thread I will ask them too bleed the slave cylinder first as it's probably worth doing.
chances are the slave cylinder wasnt bleed so id defo get done!
get it bled before hand so dont try sell you a gearbox
It was the cold air feed tube that looked to be in the way, didnt look at whats required to get it out. Will have another look tomorrow. Thanks for the feedback guys![]()
You might have to jack car up to unclip metal pipe, not sure. If can do from ontop great but got start pulling stuff out.
On subject of this post - done a full day of track time at oulton without a single issue!!
