New noise developed under the bonnet ...
Discussion in 'Engine, Gearbox, Exhaust and Air Intake' started by CallorFold, Jun 11, 2016.
  1. CallorFold
    CallorFold Platinum Member
    965
    Car:
    Clio 220 Trophy
  2. Kazumz
    Kazumz
    1,500
    Wiltshire/Swansea
    Car:
    Clio RS 200 Gordini
    Sounds belt related. Checked your pulley also?
    Sent from my SM-N9005 using Tapatalk
  3. CallorFold
    965
    Car:
    Clio 220 Trophy
    The light tapping noise has been there since owned the car (getting on for year and half now / 13K miles) - seem to remember reading a few threads stating this was pretty normal.... Just the new squeal that's a bit worrying - does the dephaser pulley normally squeal? or just tap?
  4. Kazumz
    Kazumz
    1,500
    Wiltshire/Swansea
    Car:
    Clio RS 200 Gordini
    I was getting a couple of noises and whatnot similar to this before I had my belt change. It's quite silent now though.
    I'd pull the right wheel and lining off with the car up on a ramp to check where the noise is coming from. It seems to be in the belt area but best to check before forking out loads of money and finding out it wasn't that!
    I couldn't tell you if the noise is a pulley as there are plenty of moving parts. Best to check visually and by listening with the liner off.
  5. CallorFold
    965
    Car:
    Clio 220 Trophy
    Just been out to have another listen, it really doesn't seem like it is the Aux belt, seems higher up in the engine bay. Sounds like it's coming from just below the oil filler cap, dephaser pulley/cambelt are behind that?
    Any chance it could be the cambelt? Or does dephaser seem more likely? Think I'll end up passing the car to my mechanic to have a look at. ****.
  6. Kazumz
    Kazumz
    1,500
    Wiltshire/Swansea
    Car:
    Clio RS 200 Gordini
    I'd certainly pass it to a mechanic if it's worrying you, for a proper diagnosis. There's nothing like an experienced mechanics ear. When was the belt change done last?
  7. CallorFold
    965
    Car:
    Clio 220 Trophy
    Cam belt was done in 2013 so definitely shouldn't be due yet, and it's way, way below the mileage requirement.
    Also to add to the troubleshooting, when the clutch is depressed the noise stops.
    Maybe clutch related rather than cambelt/dephaser? Will give my mechanic a call a little later today and see if I can pop it round for him to have a listen
  8. Kazumz
    Kazumz
    1,500
    Wiltshire/Swansea
    Car:
    Clio RS 200 Gordini
    I was going to reply and say it's probably clutch related yesterday but you mentioned you thought it was the dephaser but I can see you've edited your post now and mentioned you reckon it's the clutch. Yeah mate, I can see it being transmission related. Could be resonating from the gearbox up in to the engine bay but that doesn't explain why you're heading it from the left side of the bay.
    Sounds like a bearing or something the like.
  9. CallorFold
    965
    Car:
    Clio 220 Trophy
    Yeah unfortunately being non-mechanical I'm diagnosing via YouTube videos and other forum posts so learning as I go!
    I believe a clutch job is probably on par cost wise with Cambelt/Dephaser job? ~£500?
    From what I've read, if it's clutch bearings/thrust bearing/that sort of thing, its cost effective to have the clutch changed at the same time due to the labor involved?
    Car is a 2008 (so 8 years old now) with 65K on it and to my knowledge is still on original clutch - any idea what the general life-span in the Clio is/expected change?
  10. Kazumz
    Kazumz
    1,500
    Wiltshire/Swansea
    Car:
    Clio RS 200 Gordini
    Clutch life span is all to do with how you drive it bud.
    Clutch job is naturally expensive, yeah.
    I'd pop in a new clutch too mate, yeah. While your there kind of thing!
  11. DS197
    DS197 POTM Winner - June 2017 Paid Member
    1,650
    Car:
    Clio 197
    Also worth changing the slave cylinder too when replacing the clutch
  12. CallorFold
    965
    Car:
    Clio 220 Trophy
    Mechanic has disagnosed clutch thrust/release bearing or whatever it's called
    Is this a separate component or does it come as part of the clutch/clutch kit?
    I can see on Renaultparts it's £190 for clutch kit
  13. Foxspeed
    15,746
    Car:
    megane trophy 300edc
    clutch kit = clutch cover/drive plate/release bearing (normally) but some places only class cover and drive plate as a "kit"
  14. CallorFold
    965
    Car:
    Clio 220 Trophy
  15. sevenfourate
    sevenfourate Devotee of OCD Paid Member
    8,440
    Lowestoft, England.
    Car:
    Citroen C2 GT
    ^^^^Dont suppose a clutch is "desperate" (Big job on these cars ?). Im guessing its not a quick swap.........
    But - hopefully diagnosed correctly 1st time, and its normal wear and tear / routine work on a car a few years old unfortunately.
    ****What miles has you car done out of interest ?
  16. Foxspeed
    15,746
    Car:
  17. CallorFold
    965
    Car:
    Clio 220 Trophy
    Its on 65,500 now
  18. sevenfourate
    8,440
    Lowestoft, England.
    Car:
    Citroen C2 GT
    It dont owe the car much then and has done ok in a performance vehicle.......
  19. CallorFold
    965
    Car:
    Clio 220 Trophy
    Yeah it's just going to be the labour costs involved in changing it out really. GF's Dad does bits and bobs on cars and reckons he might be able to do the clutch so waiting to hear from him.
    If I can grab the clutch kit for ~£190 from Renaultparts and get some assistance fitting it, it shouldn't be too bad. Fingers crossed
  20. sevenfourate
    8,440
    Lowestoft, England.
    Car:
    Citroen C2 GT
    Day after i had my manifold fitted, a friend of mine had a clutch fitted in his 10 plate Type-R Civic.
    Done in the same garage as i use, so i saw it happening. That was a suspension out, sub-frame dropped effort; like the mani fitting on an RS. I believe he said with an slightly uprated clutch he was looking at around £600 all-in.
    Same scenario for a clutch in ours in regard of dropping engine slightly, sub-frame out etc ??
  • Share This Page
