Lower seat rails / suspension questions
Discussion in 'Clio 200 Area' started by Bodyboarder81, Jun 11, 2019.
  1. Bodyboarder81
    Bodyboarder81 Paid Member
    54
    Car:
    Porsche
    Hi all , new on here so take it easy :smile:
    Picking my little 200 up this Saturday and already know I’d like to fit lower seat mounts to the Recaro CS seats .
    Where’s the best place to get them from ?
    Are their differences that I should be aware of ones available ?
    Also looking at a slight lower ride height and spacers . Had my heart set on a set of Bilstein b14’s but hearing good things about the H&R springs . The car has the cup pack on it , if this has a bearing on things . Also 20mm spacers are what I’ve seen used mainly ?
    Bit of background.... the car will be used for 2-4 track days a year and general use ( probably 4K a year )
    What would you suggest ?
    Any help much appreciated
    Thank you :smile:
    lewishunter98 and Beany like this.
  2. Beany
    Beany Platinum Member
    2,060
    Doncaster
    Car:
    RB 200 cup
    Bodyboarder81 likes this.
  3. Bodyboarder81
    54
    Car:
    Porsche
    Thanks for the link and info , much appreciated.
    I’ve heard so many mixed reviews on Gaz suspension over the years , it’s just put me off , wrongly or rightly !
  4. Beany
    2,060
    Doncaster
    Car:
    RB 200 cup
    Fair enough, they did get a bad rep awhile ago but myself & fellow track enthusiast @Big Ben both have them on ours and they’re great.
  5. Bodyboarder81
    54
    Car:
    Porsche
    Yes I’m sure they are ok ... but never had any issue with Bilstein’s over the years and bearing in mind this is mainly a road car , I’m hoping they or the H&R springs will be adequate for my needs .
    What in the way of front camber can you achieve ? Think I’ve read they are none adjustable, but can you get camber bolts or is it only adjustable top mounts you can use ?
  6. Beany
    2,060
    Doncaster
    Car:
    RB 200 cup
    For the newer top mount designed 200s there isn’t an easy solution to fit adjustable top mounts. Ben has a 197 and they come with adjustable top mounts and his is set up with -2 degrees camber and I understand you can go further!
    I’ve heard H&R springs are good for lows but they’re crashy on the road
  7. Bodyboarder81
    54
    Car:
    Porsche
    Oh ok .... don’t want crashy at all !!
    I did test drive the Clio 197 from k-Tec with Bilstein’s and top mounts ( black car with white wheels ) very impressed with the ride quality to be honest . Looks like the more expensive option then.... as always !!
    Beany likes this.
  8. Doogle
    706
    Plymouth
    Car:
    BMW e46 330cd
    Id recommend Josh Wheeler's lowering seat mounts also. Theres a few options, depends on how much you want to spend. There are 3 other options on the market:
    1. Flacsi, he sell's a modification kit which will lower the frame but this is fixed drop and although probably secure, doesnt look that secure.
    2. Rentune made their own bespoke frame with a fixed 50mm drop. Great quality, cost a few hundred.
    3. Another chap on the Facebook Clio197/200 facebook group had made something similar to Rentunes above but even better. A bit more again at £250 I think.
    Josh's has 3 drops (secured by bolts so does mean taking the seat out to adjust) of -30mm, -40mm and -50mm.
    As for springs, I found H&R quite crashy and linear. Eibach's seem better IMO but if you are going to do it right, Bilsteins seem to get brilliant reviews.
  9. lewishunter98
    lewishunter98 Paid Member
    468
    Southampton
    Car:
    Racing Blue Clio 197
    Welcome!
    I'd recommend the B14'S over H&R springs, I went from the springs to bilstein coilovers and the ride is much better on the road. It's firmer but dampens a lot better, you'd get thrown about a lot on springs haha!
    I ran adjustable top mounts with my coilovers for a very short time and I much prefer the OEM ones for road use. Bare in mind I don't drive it much at all, but they just made me so conscious of bumps/potholes etc. The final straw with them was when I hit a bump in the road and smashed a rose joint through.
  10. Bodyboarder81
    54
    Car:
    Porsche
    Ok thanks guys , some great replies and info .
    So josh’s mounts And Bilstein b14’s it is then !
    Best place to buy the Bilstein’s ?
    Beany likes this.
  11. Beany
    2,060
    Doncaster
    Car:
    RB 200 cup
    Kam racing is where I’ve bought alot of stuff and their reward system is nifty!
    £750 for mk3 Clio
  12. Bodyboarder81
    54
    Car:
    Porsche
    .... also I’ve heard lots about engine mounts ... I’m not after anything that causes vibrations to be honest . I’m thinking of buying a new torque arm and dog bone from Renault to freshen them up. Good idea ? Or get the Powerflex ones ?
  13. Bodyboarder81
    54
    Car:
    Porsche
    Also does anyone have a user name for josh who does these seat mounts ?
  14. CaptainCaveman
    CaptainCaveman Paid Member
    61
    Car:
    LY 2011 RS 200 FF Cup
    Hi there,
    I would strongly discourage you from lowering springs, and specifically the H&R. Same as you, I assumed the H&R would be a low cost improvement to the car, whilst adding the benefit of the extra visual appeal. However, the H&Rs are rubbish, at least with Cup dampers. Having since compared the specs to the stock cup springs, the front springs are actually softer than OE Cup springs, and the reduction in damper travel, means that you end up bouncing all over the place at speed, as the damper struggles to contain all the momentum within the reduced stroke.
    The Cup setup is well proven, and universally praised, and one of the things that makes the car so good. Unless you're adding decent coilovers, then I wouldn't bother with just springs. They really do ruin the ride, but more importantly the composure of the car over bumps.
  15. Clint197
    Clint197 Gold Member
    13
    Car:
    197 r27 f1, Audi A5 2.0tfsi Quattro Sportback REVO stg 1
    I found him on the Facebook group if you're on there. He also has an Ebay shop.
  16. Bodyboarder81
    54
    Car:
    Porsche
    Yes , made my mind up and it’s the Bilstein’s I’ll be going for . Along with new genuine Renault dog bone / torque arm.
    Some ad08r tyres , spacers , lowered seat mounts , private plate , etc etc ... have a shopping list as long as my arm already and not even bought it yet
  17. Doogle
    706
    Plymouth
    Car:
    BMW e46 330cd
    H&R's are very linear in their spring rate, Eibach are more progressive. Bilstein coilies are the best way.
    Josh does have his mount on eBay.
  18. Bodyboarder81
    54
    Car:
    Porsche
    Yes been in contact with him ... unfortunately he doesn’t have any side panels that hide it all and make it look factory at the moment . Also was hoping to get a passengers side as well . Don’t think he does them . Just wondering how it would look ... with one seat being 30-50mm lower than the other ? It’s little things like this that plays on my mind !!
    sevenfourate likes this.
  19. sevenfourate
    sevenfourate Devotee of OCD Paid Member
    8,437
    Lowestoft, England.
    Car:
    Citroen C2 GT
    Really ? ! Hmmmmmm.........
    It's not 'amazing' with. Its 'ok' if i'm honest. I wasn't unhappy. But it wasn't stand-out good as in looks / gap / matching the passenger side etc.
    Without would look truly shocking - and like you i wouldn't even consider that option. At any price. Or even FOC !
  20. Bodyboarder81
    54
    Car:
    Porsche
    No ... in my mind it’s both sides , with the blanking plate or nothing :worried:
  • Share This Page
