Looking for advice on tackling a suspension/steering refresh - 2010 Renault Clio RS 200 Cup
Hi all,
I'm in the process of refreshing the suspension and steering components on my early 2010 Renault Clio RS 200 Cup and was hoping to get some feedback from anyone who's tackled these jobs before.
I'm confident with the spanners, but I'd like to know which jobs are relatively straightforward and which ones have the potential to become a nightmare due to seized bolts, special tools, alignment requirements, or hidden complications.
The list currently includes:
  • Replace outer track rod ends
  • Replace inner steering rack joints
  • Drop links
  • Top mounts
  • Anti-rotation link
  • Swivel hub bearing refresh
  • Front shocks
  • Lowering springs
  • Rear cup shock absorbers
For those who've done any of these jobs on a Clio 197/200, I'd be interested to know:
  • How difficult were they?
  • Any jobs that were particularly awkward or time-consuming?
  • Any special tools required?
  • Any bolts/components that are worth replacing as a matter of course?
  • Any common pitfalls or "wish I'd known that before I started" moments?
The aim is to give the front and rear suspension a proper refresh while everything is apart, so I'm trying to get a realistic idea of the workload and what to expect before diving in.
Thanks in advance for any advice or experiences you can share!
Out of all those, the one most likely to give you grief I'd say is the upper and lower swivel hub bearings. Some kind of press would be very useful to get the old ones out and the new ones in. They are often seized. Otherwise you're relying on a bit of brute force. I would also suggest budgeting for replacing ABS sensors as sod's law suggests that at least one will snap while you're in there.
The rest of it should be no worse than other cars with jobs of that nature.
Reactions: ck10_cup
You have not mentioned the lower arms. Here is a video link for the assembly. You do need some tools. I have done this quite a few times and I can pull the suspension upright, change the spring and refit in about an hour, but you need good tools. I would try undoing the bolts/nuts to check if they will before starting the job. The upper ball joint and the lower arm ball joint are hard to split, but the map gas thing does work but be careful around the rubber of the joints. Pressing the ball joints is not as straightforward as pushing them out, as they do not sit square on the press and the ball joints can be different sizes by a millimeter or so. The genuine Renault Sport ones are smaller, but I have been using the eBay ones without problems. Heat helps the press out and press in process regards force that's needed and stops widening the holes. Use six-sided sockets to stop ringing bolts and nuts and the torx screws (get short torx sockets) for the ABS sensor and brake pipe bracket. Pulling the sensor needs care and time to save money.
If its not been apart recently you're likely to have a scrap with the lower control arm to hubs not wanting to split off, and the pinch bolts for the shocks being seized. Steering rack connection is a bit fiddly in the footwell. Most of the time I just drop the subframe off as it isn't a load more work by the time you've got to the control arm bolts and gives far more access.
I'd add two things to the list: new top-mount bearings and new pinch bolts/nylocs for the shock and hub joints, since they're cheap and often corroded. Also book a proper alignment after the track rods and springs are fitted — don't rely on counting threads. For the inner rack joints, check whether you need a specific crows-foot or socket; access is tight and it's easy to damage the rack gaiter if you rush it.
