KW V1 settngs
Not sure about the highest and lowest settings but can tell you how mines set up.
Got mine set to lowest on the rear and about 1.5" from lowest on the front.
Cheers mate.
I am trying to calculate the allowable clearances and thus the necessary adjustments in order to avoid rubbing, since the car sits on 18's. Does anyone have any experience with coilovers and tyre size of 225/40/18? For example 20mm all round will give sufficient clearance? The goal is to improve handling and not go very low.
Many thanks.
with 18" you wont get any rubbing as the overall size isnt that different.
im running 25mm spacers and still ok.
