Got this weird knocking noise coming from the N/S/F. Its only when going over gentle bumps and makes this quite heavy knocking noise. Had a quick look at roll bar links and the bottom ball joint and it looked ok. Any common failures ?
If it's the top mounts, then you would notice it pretty quickly with the car off the ground. Also check that the spring hasn't snapped, quite common at the moment as the roads are in rubbish condition!
Check the plastic around the spring hasn't popped out, as it creates a metal on metal clunk when the spring unloads - jack up pop the wheel off and reinsert if it has - easy fix if the case (had the same problem on mine)
Bl**dy speed ups! :-D
