Heppy997
My car seems to have developed a knocking noise coming from the front of the car. It occurs at low speeds when turning the wheel and most notably when going over bumps. You can kinda feel it through the pedals.
Ive had the manifold replaced recently with a Toyosport one, at first I thought it might be this hitting the subframe, but i had upper and lower engine mounts done so it shouldn't be......also on full lock to the right, the inside of the wheel rubs against the control arm (?) so could it be the lower ball joint?
video: https://youtu.be/ylcWwEkZ9jg
