JP Exhausts System.
Just take any cat-back system and add £50-70 for a decat pipe, job done.
The standard Cat isn't that restrictive anyway really. Is there a particular reason why you want to lose it?
I have the older ''single box'' version of the K-Tec which has one rear silencer instead of the two that the newer system now has. I believe this model one was made by Magnex however I don't know who make the new ones for them. The quality on this one is very good, had no fitment issues and never had any problems since fitting. It sounds lovely and certainly smoothed out the power through the range whilst reducing the flatspot I had after chopping the centre silencer from the standard system... It's not as raspy as that, but it is a bit louder. I'm happy with it although I will probably be making my own setup towards the end of the year.
Keep your eyes open for a second-hand one and save yourself a couple of hundred quid.
Willis is yours a yozza ?JP Exhausts System.
So I'd need a decat to replace the centre silencer?
Sorry for being such a Nooob
No you have cat centre silencer then back box Mate
Argh I don't know what to do.
I'm really undecided against the K-Tec now. I want something with a good bit of rasp, pops and bangs![]()
No mate, it's the original style of K-Tec. So it has a centre silencer the same as the newer ''two rear box'' model but it has only one rear silencer similar in size to the Yozza... It's a bit of a hybrid and from what I can gather is based around the Group N system made by Bastuck (also what the Yozza appears to have been based on). But where as the the Yozza and Bastuck have no centre silencer, the original K-Tec one does so it's not quite as raspy and sounds like this...
[YOUTUBE]http://www.youtube.com/watch?v=sDGxnSNFXOs[/YOUTUBE]
Scott, like Hippy has said after your Manifold you have your Secondary Cat and then the next box along (front to rear) is your centre silencer. Removing JUST this from the standard system will give you a similar sound to this...
[YOUTUBE]http://www.youtube.com/watch?v=X065zVA55Fw&NR=1[/YOUTUBE]
