does anyone know where there is a switched ignition feed in the 197?? cheers steve
S stevp197 Oct 23, 2011 #1 does anyone know where there is a switched ignition feed in the 197?? cheers steve
ben_r1 Oct 23, 2011 #2 I took my feed for the nitrous controller off the 12v socket. It's simple to get to and can be easily earthed. If you require a Light feed for gauges etc this can be found behind the stereo on an input, forget the colour it is.
GrumpyTwig "the troll hunter" with added boost! Oct 23, 2011 #3 Yellow one in the radio bundle is ignition switched from what I recall.
S stevp197 Oct 23, 2011 #4 cheers for the reply guys i want to get the snooper hard wired in and didnt realise the lighter sockets were switched i thought they were constant live but hadnt checked,
ben_r1 Oct 23, 2011 #5 On some cars, even mk2 clios, the socket is constant live but on the 197 it's ignition switched, I would assume the same for the 200.
vivid white Platinum Member Nov 8, 2011 #6 Hi all, If using the yellow feed on the headunit for the live what about an earth? Thanks
S stevp197 Nov 8, 2011 #7 i ended up using the cigarette lighter and then used a bolt near it to earth with a ring crimp
vivid white Platinum Member Nov 8, 2011 #8 Cool thanks. ill have a look into this method and see what i can do.
