https://www.ebay.co.uk/itm/RENAULT-...h=item5b4ce16a1b:g:XUsAAOSwFxJbrL7K:rk:1:pf:0
My nsf lower balljoint is gubbed and considering options. The above link is to a refurbished swivel hub with new lower joint from Four Ashes Renault. There is a £50 deposit on top until they receive your old unit. What are the thoughts of others on this compared to just purchasing a lower joint from RSport at £56.
Will I have to also have to do the top joint and will I have an issue refitting the abs sensor?
When they went to fit the new track rods they said the insert on the hub carrier the track rod end goes through is missing and was probably why my steering had play???? How on earth it could be missing is beyond me, it is impossible to fall out by itself unless it just dissolved???!!! They said you cannot buy the insert separately and I had to buy a complete new hub carrier and new wheel bearing (unfortunately I had not seen the above ebay link).
Thanks, I had a look at guide and all seems relatively straight forward apart from the chocolate bolts Renault used.It's worth checking the upper ball joint while you're there, if it requires replacement I reckon it also needs to be pressed out. I didn't have any issues with the abs sensor when I removed the upper hub but the car was only a few years old back then, I hear they can seize in quite tight.
You'll need a decent ball joint splitter to split the lower and upper Hub Carrier. There's a full write up in the how to section.
Gutted to see this. I feel like I have just been raped by Richard Sanders Renault Northampton. Took car to them last week due to vague steering and check esp light coming on. They diagnosed the issue as play in track rod arms and worn threads between inner and outer, (although they fitted a new track rod arm back in July for the previous owner....) Should have taken the car somewhere else then but I agreed for them to replace both inner and outer, (they said both sides needed doing). When they went to fit the new track rods they said the insert on the hub carrier the track rod end goes through is missing and was probably why my steering had play???? How on earth it could be missing is beyond me, it is impossible to fall out by itself unless it just dissolved???!!! They said you cannot buy the insert separately and I had to buy a complete new hub carrier and new wheel bearing (unfortunately I had not seen the above ebay link). Final bill came to £1075!!!!!!!!!!!!! I had already bought upper and lower ball joints from R-Sport ready to replace the originals as part of a suspension refresh in due course, hence now having a spare lower for sale. Will never take my car to a Renault main dealer again! Will most likely drive to RS Four Ashes in Wolverhampton instead next time any work is required!
You have to clean the upper bearing extra well, especially the area that is pressed through the aluminum part when pressing out, especially the groove for the circlip. And immersing the part in almost boiling water for 2-3 minutes directly before pressing it out also helps a lot.
