Is there some trick to get Torque Lite or other Android apps to work with Clio Mk3 200 Sport?
I've tried 3 bluetooth OBD2 dongles ("V-Gate" , "Moonar", and "Smaier "), each of which were able to communicate with several Honda's I plugged them into, but not with the Clio. I've tried with the Start button pushed once (engine not running) and with the engine running. Only the Moonar (link above) was able to connect using Torque Lite, but even though it showed rpm it wasn't able to say anything about fault codes.
Is there something I'm missing? A specific communications protocol that I should be specifying somewhere in some settings?
