Been chasing a NS clunk around trying to eliminate it recently and have explored many areas. So far i have changed the NS inner track rod and outer track rods on both sides, also replaced the lower anti rotation droplinks on both sides.
I have ruled out the balljoints as they are solid and were replaced by the previous owner.
My symptoms are (with the clio on the deck) I can feel slight play at the 12/6 position (which led me to initially believe balljoints) - this play isnt present when the car is jacked up and in the air however!
Without jacking the clio up, I can feel the movement in the wheel and also the strut. Which then pointed towards top mount / shocks, checked the top mount (thinking it could be loose) but its fine (&tight) and yet the wheel movement is still there. So in my eyes the fault lies with the shock.
Interestingly i can feel the play on the deck but if i jack it up and then drop it down to the floor again , the movement has temporarily gone, until i drive the car any distance and then i can feel the movement again when rocking the wheel by hand (nothing is felt from the cabin apart from an annoying knock over uneven ground).
Which leads me onto the point of this thread. I need to replace the NS shock (and they will be replaced both sides), i will also replace the top mounts with Febi items as i cant 100% guarantee their condition until the shock is removed, by that time, if i dont have replacement top mounts i am stuck.
How far do i go...I am aware of the drivers side spring being replaced by the previous owner (can still see the label on it), which means the NS one is older - do i replace the springs all round too? Lowering springs ?
Also whilst i am replacing the front shocks (& maybe springs) do i also replace the rear shockers.
Hopefully this gives you an insight as to the dilemma i have now - a bit of an essay but it may help others, made more of a dilemma because of the £££ should i decide to replace shocks/springs/top mounts all round.
Any thoughts ?
Any thoughts ?
