How do you remove the airbox ?
Just wondering how you remove this and all the pipes, there's a post in the how to section but does not have any pics
Pipe all just pop out from each other, apart from the one that connects to the Inelt with a jubilee clip. The Airbox body itself is attached to the bulkhead and you need to give it quite a pull to dislodge it but be careful as it's easy to snap the little feet/plug things that hold it on. The extra box under the battery tray is connected to the from bumper supports and is a fiddly one, you need the battery out at the least and could do with getting the front undertray off to aid access from underneath...
Disconnect the battery, removing the negative terminal first. There is a bolt holding the battery in at the front you will need to undo before you can lift it out. Once it's out, disconnect the fuse boxes from the battery case, then unclip the battery case. I removed the air box lid to give me a bit more room. It's a pig to get it out, try and keep all the wires held back. Getting the case back in is a ****. Disconnect the air box from the outlet and two inlets. The air box has no screws so just pulls out. Remember to double check you have everything connected up again afterwards.
