How do i relieve fuel pressure
I'm not sure as the pump is in the tank along with the regulator as far as I know!?!
Why would you want/need to anyway?
Hmmmm iv been read so where there might be a screw there to do something with it
I'm putting on new inlets that have been matched but I never took the old ones off
But could I just unbolt the fuel rail from the plenum and get around it that way? Or would fuel just start pissing out of it?
if you leave it a while the pressure will drop anyway
so if left overnight cannot see much pressure being in there
Hmmmmm I was hoping to do this tonight if my plenum is in, want it done for Saturday a few hours to relieve presure would be enough?
But if I'm only in bolting the fuel rale from the plenum would it be ok to just leave it as I'm only moving it out the way
Just talked to an ex rally mechanic and he seems to think I'd be safe enough just in bolting the rail without disturbing anything pressurised
av4625 Clio 197 Area 7
chris_blue Clio 197 Area 6
D Clio General Chat 5
Christian J Clio 197 Area 10
A Clio 197 Area 8
