Thanks,i've seen a similar diagram,thing i don't get which doesn't match the diagram is that r107 connector,when i saw that on the diagram i thought that was a seperate 2 pin connector between my UCH and the pump,and 'that' would be my problem but i can't find it!!This connector is seemingly changing the wire colours too towards the pump.there should be a live feed coming back out the UCH to activate the washer pump,but none of the wires light up when i pull the wiper stalj??
There is a 'very' dim light on some of them,i'm 'sure' it's either a faulty BCM or ir's that r107 connector has a bad connection??
I have a diagram of the r107 connector location but it just seems to be around the UCH,and is described as being st 'the dashboard front of engine'???Eh??Where's that then??
