HELP - Airbag Light Issue
Hello all, cut my long story in short.
I've installed momo steering wheel and hub previously with 3.9ohm resistor x2
It was running perfectly without warning lights for a week but then the light pops suddenly
I ran OBD a read codes: D071 & D072
Driver front airbag circuit 1
Driver front airbag circuit 2
Any idea what to replace / fix / try?
I've tried a new clock spring and replacing the resistors but no luck.
Also tried to clean the dust under driver seat's plugs.
Thanks in advance!!
It was working perfectly fine.
235775052_4454546261264315_4612566950935754258_n.jpg 236217038_376992747329705_6761450449102675727_n.jpg
Airbag light & Service light pops and OBD said D071 & D072
That’s the steering wheel airbag. Personally I’d get someone with CLIP to turn them off. Failing that have a look at the connections of the resistors.
