hanbrake only works on one side
R27#239
Just wanted peoples opinion on this problem.
My handbrake only locks on one side, i cant adjust the mech on the lever as this tightens both sides.
Any thoughts?
oliver
Check in the centre console. It's two bolts to remove it, at the rear by the cup holder. Then check whether the cable hasn't come out of the bracket.
Failing this his I would say the cable has snapped.
Cable is intact and in the holder. It would appear the adjuster inside the caliper isn't wprking. I've wound the piston back in and it doesn't come out to take the gap up so i get a long pedal.
Guess I need to strip the caliper
I stripped it all down and all was ok inside.
Rebuilt, refitted and bled it. I manually adjusted the piston out to just before the pads contacted the disc and adjusted the handbrake to suit.
All sorted
