Edit for the future:
Heres the info I've found on H&R Spacers (Eibach are pricier so I didn't bother researching them)
H&R DRA system 25mm part:5035601:-
This system bolts to your hub, then you use your normal bolts to fit your wheel. This is only available in 25mm fitment (per axle) and can be bought from several places inc. europerformanceparts.co.uk for £95 - This kit does not require longer bolts
H&R DA system 20mm part:40365601:-
This system requires longer bolts like I've posted above (14mm x 1.5 x 50mm) These can be bought from lots of places, the cheapest UK seller is:
Larkspeed at £77 per pair (£164 inc postage for 2 pair)
You can also pick them up from German eBay by searching "H&R Spurverbreiterungen Clio 40mm" or using the part number above. These worked out at £61 per pair plus delivery (£138 inc postage to UK for 2 pair)
^^ these can also be bought through Amazon, UK eBay and EuroPerformance so you could check their prices too.
General information about spacers in this Vid from Driftworks.
http://youtu.be/uagmGqeomng
