Ok, this is starting to really do my head in so allow me to explain.
I have an R27.
Basically no matter whether the car is hot or cold when i'm crawling along in 1st, 2nd or 3rd changing gear from one to the other and going slowly as this noise doesnt happen when going for it, i get a click after every gear change.
So for example.....start the car, leave for a few minutes before driving, press the clutch pedal and select 1st gear, gradually release the clutch pedal whilst pressing the gas like normal, by this time you are moving slowly probably between 5-10 mph. When the clutch pedal is fully released almost immediately after i get a click/tick noise which comes from the front passenger side of the car around the gearbox area.
If i do EXACTLY the same in 2nd gear at low speed, no stereo going or anything i here it again but maybe slightly less of a click because i am going that little faster but none the less it is still there.
This noise does NOT sound like something is wrong with the car, it sort of sounds as if its supposed to do it for some reason but i wanted to understand what others thought? Nor is this noise a constant click/tick its a one off directly after 1st/2nd/3rd gear. It may also do it in the other higher gears but because of the extra speed/faster rotating wheels i may not be able to hear it perhaps.
PLEASE HELP ME its so annoying......if its normal then fine i can accept it i just need to know?!
Thanks!!
I have an R27.
Thanks!!
